Hi makers,
I need some help with support settings in cura the supported areas on the print looks like they where not supported
the density was 25% printtemp by 200 and cooling 100%
Did you choose the distance between support and model too high? - This means it is easy to remove.?
The z difference is at 0.1
Does cura have a ‘support interface’ option? Try turning it on, it should make supports easier to remove / give a more consistent support layer for the part
Yeah it has an option like this but never used it i will give it a shot
