Support structure trouble
I don’t sure is group right for the issue I don’t sure have I done rigth with constrution of the support structure. The trouble is that in use is double extruder. I have used left extruder is head extruder (PETG) and right extruder is support (PVA). I can set right setting so that print result isn’t good support upper bandage (inaccurate surface). At first add support structures to object and set right extruder is support. Am I missing some else settings. I don’t get done accurate settings for support. In additional what about adhesion setting, interface setting left or right extruder. I don’t found any manual of the issue.
Best regards,
Jan
Look Here
I suggest trying PLA instead of PRTG.
PRTG has so much stringing if used for dual nozzle prints. That might improve your print a little.
Hi
I focus my question how should make support by Luban when you have dual extruder. What kind of things should you do in Luban. I know really different filaments behave differently.
Best regards,
Jan
