Stuck on print preprocessing
Sometimes (not always), after a succesful print, I go to print a new one in a diferent plate.
when I click on the print button, the preprocessing modal appears and gets stuck trying to load the filament config.
the only workaround for now is to fully close the program (including the processes that are left behind (there are about 20 processes in there left behind). If I don’t close these, the app doesn’t reopen to the main window
the list of processes
What version is your software? Could you take a screenshot? The issue in the screenshot may also be related to your network and your computer’s performance. Try to rule out these two factors:
1. Use antivirus software to clean up your computer’s junk files.
2. Try connecting to the machine via local area network (to rule out cloud connection issues).
OR take a test in here:
This is in a LAN environment. No other network issues with other apps. Also it works if I fully close the app (including zombie processes) and restart everything (but that’s annoying)
Version is the latest one 2.3.1
I’ll do the test and report back
Currently not having the issue, just posting this for reference and to double check that this is what you asked me for. I’m sure it will happen again today or tomorrow and I’ll get the same info. Let me know if this is it or you need something else.
Results
`Wed May 20 10:17:14:`
`Wed May 20 10:17:14: ========================================`
`Wed May 20 10:17:14: test Snapmaker Orca(GitHub) start…`
`Wed May 20 10:17:14: test Bing start…`
`Wed May 20 10:17:14: [test Snapmaker Orca(GitHub)]: url=https://github.com/Snapmaker/OrcaSlicer`
`Wed May 20 10:17:14: [test Bing]: url=http://www.bing.com`
`Wed May 20 10:17:14: test Bing ip resolved = 95.100.86.220`
`Wed May 20 10:17:14: test Bing ok`
`Wed May 20 10:17:18: test Snapmaker Orca(GitHub) ip resolved = 140.82.121.4`
`Wed May 20 10:17:18: test Snapmaker Orca(GitHub) ok`
`Wed May 20 10:17:18: ========================================`
`Wed May 20 10:17:18:`
`Wed May 20 10:17:52:`
`Wed May 20 10:17:52: ========================================`
`Wed May 20 10:17:52: test LAN Device start…`
`Wed May 20 10:17:52: [test LAN Device]: server=192.168.1.79, port=1884`
`Wed May 20 10:17:52: — Step 1: Network Layer Test (ICMP Ping) —`
`Wed May 20 10:17:52: Starting ping test to 192.168.1.79…`
`Wed May 20 10:17:52: test Cloud Server start…`
`Wed May 20 10:17:52: [test Cloud Server]: ``server=a1pr8yczi3n0se-ats.iot.us-west-1.amazonaws.com``, port=8883`
`Wed May 20 10:17:52: Starting ping test to ``a1pr8yczi3n0se-ats.iot.us-west-1.amazonaws.com``…`
`Wed May 20 10:17:52: test Login API start…`
`Wed May 20 10:17:52: test Upload API start…`
`Wed May 20 10:17:52: [test Upload API]: url=https://public.resource.snapmaker.com`
`Wed May 20 10:17:52: [test Login API]: url=https://id.snapmaker.com`
`Wed May 20 10:17:52: test Upload API ok (403 - access restricted, but server reachable)`
`Wed May 20 10:17:52: test Login API ip resolved = 99.84.9.128`
`Wed May 20 10:17:52: test Login API ok`
`Wed May 20 10:17:55:`
`[OK] Ping round-trip time: 18.177ms (average from 4 samples)`
`Packet loss: 0% (4/4 received)`
`[OK] Ping test successful (4/4 packets)`
`Wed May 20 10:17:55: — Step 2: Transport Layer Test (TCP Connection) —`
`Wed May 20 10:17:55: DNS resolve time: 2 ms`
`Wed May 20 10:17:55: test LAN Device connected`
`Wed May 20 10:17:55: [OK] TCP connection established in 11 ms`
`Wed May 20 10:17:55: Total test time: 13 ms`
`Wed May 20 10:17:55: — Test Summary —`
`Wed May 20 10:17:55: [OK] Network Layer: Ping test completed (see RTT above)`
`Wed May 20 10:17:55: [OK] Transport Layer: TCP port 1884 is open and accepting connections`
`Wed May 20 10:17:55: Connection Quality: [Level 1] Excellent (RTT: 11 ms)`
`Wed May 20 10:17:55: test LAN Device ok ([Level 1] - Excellent, RTT: 11 ms)`
`Wed May 20 10:17:55: ========================================`
`[OK] Ping round-trip time: 195.446ms (average from 4 samples)`
`Wed May 20 10:17:55: DNS resolve time: 14 ms`
`Wed May 20 10:17:55: test Cloud Server connected`
`Wed May 20 10:17:55: [OK] TCP connection established in 164 ms`
`Wed May 20 10:17:55: Total test time: 179 ms`
`Wed May 20 10:17:55: [OK] Transport Layer: TCP port 8883 is open and accepting connections`
`Wed May 20 10:17:55: Connection Quality: [Level 3] Fair (RTT: 164 ms)`
`Wed May 20 10:17:55: test Cloud Server ok ([Level 3] - Fair, RTT: 164 ms)`
Since your LAN test looks clean and the issue clears only after fully closing Orca, this feels less like a network problem and more like the app getting stuck in some background process or connection state.
Next time it happens, maybe check Task Manager before restarting and see if there are leftover Snapmaker Orca processes still running. If killing those fixes it again, that would be useful info for the devs. It might also be worth noting whether it happens after the computer sleeps, after a failed send, or after the printer has been idle for a while.
The test results you posted look like the right kind of info to share, especially since LAN shows excellent and cloud is reachable too.
I have added three back ticks at start and end of your log to support readability.
It looks like this: `
Please feel free to share your findings with support:
https://snapmaker.formcrafts.com/u1-troubleshooting-request
@xchrisd thanks, and yes I also shared with support as well, I saw the support page after posting in this forum. But a good idea nonetheless.
@makerlog that’s what I was referring to, I quit the app, go to Activity monitor and filter processes and kill anything that looks like a leftover, then restart.
I guess that it is after the printer has been idle for a while, seems like Snapmaker Orcaslicer loses sight of the printer and even after reconecting (going to devices and selecting control) showing a green light (like it is ready to work) doesnt help.
