Snapmaker U1 Kickstarter Update – Useful Info for Backers
This topic will serve as the main thread for all Snapmaker U1 Kickstarter updates. We will post each weekly update here so backers can easily follow the latest information.
Hi U1 backers,
We shared our first Kickstarter update with some useful info for all of you. You can check it out here: https://www.kickstarter.com/projects/snapmaker/snapmaker-u1-color-3d-printer-5x-more-speed-5x-less-waste/posts/4464446
We will be sharing weekly updates to keep you informed about the U1.
Let us know in the comments what topics or details you would like us to cover in future updates. :backhand_index_pointing_down:
Updates on the firmware and software issues the reviewers (and the tech team) found, progress on filament profiles and tuning, spare part availability, basically anything that’s going to give us confidence that you’re going to get this printer working ‘out of the box’.
The tester video on the Kickstarter campaign page shows the first layer of the build plate size being molded after being taken out of the box, but it doesn’t look good from the video.
There are two places that are wavy.
The Bambu A1 was perfect right out of the box, though :slight_smile:
I would like to see some additional information about this.
Also, as I wrote in the Kickstarter comments, I was speechless when I saw the official response that ABS verification took about 10 hours.
My main goal is ABS molding with a standard molding time of 15 hours.
As others have pointed out, there are concerns that the door or cover may warp due to heat.
When using the Snapmaker A250 Enclosure for ABS molding for 26 hours, the internal temperature is around 45°C to 55°C, and the warping of the acrylic panels in the enclosure is severe.
I regularly flip the acrylic panels over and reattach them.
ABS molding users are quite concerned.
By the way, I also pledged for the top cover as a backer in the 800s.
I will definitely purchase it and share my opinion.
https://youtu.be/oWUTe1TjjKA
For what it’s worth, the mesh shown in the video also has large bed tilt after shipping. Software mesh would do a lot of heavy lifting. In my testing I learned there is already a macro assisted bed screw adjustment that takes just a few minutes to correct that skew.
There’s a good chance not all testers knew this or simply didn’t do it. [I would add, this result is still a testament that mesh correction works :sweat_smile:]
Hello, Wombley.
Thank you for the valuable information.
So there is some kind of function that can be adjusted with the head screw to perform “manual correction”?
Even if there is automatic tilt height correction for the heat bed, is it necessary to perform this “manual correction”?
If so, if it’s not mentioned in the manual, it might lead to a flood of questions in the Community like with the A350…
What’s a bit concerning is that when watching the preview user’s video, the bed calibration seems to skip measuring the left edge area. If that’s the case, could the left part of the green first-layer sheet being held by hand be causing the wavy pattern?
Agree…however…take Bambu as the example. Bed mesh and levelling is checked and calibrated before the printer is shipped and the first layer is near perfect straight out of the box, so the same should happen here, beta printer or not. This is where the basics HAVE to be done and have to be done right. We’ve gone past the days where everything had to be checked, rechecked, test print run, re-levelled, recalibrated. If manufacturers can’t get it right then they’re going to lose business, reputation and have a warehouse full of returned printers. People want a printer that is going to work as soon as they’ve assembled and run the initial calibrations, not some kit that needs a wiki just to get it to lay a decent first layer. Those days are gone…
I guess that depends what you’re printing. For what it’s worth, I’d done several successful prints on mine “out of the box” before even checking the mesh, including a first layer print.
Feedback on this is why we’re beta testers, I imagine!
Oh, and I doubt that. The mesh is, um, very detailed right now, as Sherry showed before, and it’s another point of feedback.
Hi U1 backers,
Our second Kickstarter update is live! Early reviewers and community testers are sharing their experiences with the U1. Check it out here:
https://www.kickstarter.com/projects/snapmaker/snapmaker-u1-color-3d-printer-5x-more-speed-5x-less-waste/posts/4470118
Let us know in the comments what you’d like to see in future updates.
Hi U1 backers,
Our third Kickstarter update is live! :tada:
We’re sharing details on the upcoming livestream, stories from test pilots, recent hardware and firmware improvements, plus info about the SnapDryer.
Check it out here: Kickstarter Update#3
Let us know in the comments what you’re most interested in for the next update.
Hi U1 backers,
Check out our latest Kickstarter Update #4 for the full Quick Start Guide, calibration and filament tutorials, and highlights from TCT Shenzhen.
For all details, view the full update here: https://www.kickstarter.com/projects/snapmaker/snapmaker-u1-color-3d-printer-5x-more-speed-5x-less-waste/posts/4481362
Snapmaker U1 Test Pilot Program – Key Updates & Insights
Hey U1 Community! :waving_hand:
Over the past month, our U1 Test Pilot Program has been in full swing, with 19 beta pilots testing the U1 and providing valuable feedback. Here’s a quick overview of the key highlights:
  • Why We Launched the U1 Test Pilot Program
  • How We Found the Right Pilots
  • Quick Numbers
  • Top Surprises from Beta Pilots
  • What We’ve Fixed & Improved
  • Some Challenges Remain
  • What We’re Working On
  • Real Stories from the Community
  • Tips & Advice from Our Beta Pilots
For a deeper dive into the details and full stories, check out the complete blog here:
Hi U1 Backers,
Quick highlights from the latest Kickstarter update:
  • BackerKit Survey: Surveys are sent by pledge tier, not all at once. This is where you confirm your shipping address and add optional add-ons. Make sure to complete it before the survey lockdown.
  • Delivery Timeline: Production is underway and first shipments have started. Your individual shipping date depends on your pledge tier and survey completion. You can check the estimated delivery via the FAQ or your Snapmaker account.
  • Deposit Rebate: $100 rebate for deposit holders will be issued after shipment. Early Bird – October backers can expect it by November 30.
  • Stretch Goal Rewards: Digital coupons for all U1 printer backers (including Late Pledge) will be sent on October 20.
  • U1 Accessories: First wave is now available in the Snapmaker Store with an early bird discount.
Full details here>
https://www.kickstarter.com/projects/snapmaker/snapmaker-u1-color-3d-printer-5x-more-speed-5x-less-waste/posts/4514785
New Kickstarter Update #10 is Live!
Hi U1 Community,
We’re excited to share our latest update with the U1 community!
Key highlights from this update:
  • Over 150 U1s have already been delivered, with thousands more on their way in the coming weeks.
  • Our support center has been updated with the latest firmware and software releases.
  • Visit us at Formnext 2025 (Nov 18-21) and see the U1 in person.
  • Updated survey timeline for the remaining reward tiers.
  • Deposit cashback processing update.
  • A friendly reminder about stretch goal rewards.
For all the details, check out the full update here: https://www.kickstarter.com/projects/snapmaker/snapmaker-u1-color-3d-printer-5x-more-speed-5x-less-waste/posts/4540554
New Kickstarter Update #11 is Live!
“To date, around 2300 U1 printers have already arrived at October-tier backers’ homes, and deliveries across all regions are continuing intensively.”
Hi everyone, I’d like to share the latest U1 Kickstarter update with you. This is a comprehensive update with multiple important sections. Feel free to jump directly to the topics most relevant to you:
  • October Batch Delivery Progress
  • November Batch Shipping & Arrival Estimates
  • Deposit Cashback (For Deposit Holders only)
  • Survey Schedule Update & Tips
  • Improving Rewards Delivery Experience
  • Recommended Wiki Articles & Support Links
  • Formnext Recap & Early Bird U1 Arrival Highlights
Learn the full details of this Update here: https://www.kickstarter.com/projects/snapmaker/snapmaker-u1-color-3d-printer-5x-more-speed-5x-less-waste/posts/4550867
Snapmaker U1 Kickstarter Update #12 – Highlights
Hi U1 backers,
Great news! Over 3,500 backers have received their Snapmaker U1, and with increased production, the next batch will ship about 10 days earlier than planned.
Check out the full update here: https://www.kickstarter.com/projects/snapmaker/snapmaker-u1-color-3d-printer-5x-more-speed-5x-less-waste/posts/4558687
Key topics in this update:
  1. Survey Schedule Update & Tips
  2. U1 Delivery Progress & Shipping Schedule
  3. Deposit Cashback (For Deposit Holders only)
  4. Stretch Goal Rewards Notice
  5. Essential Wiki Articles & Support Resources
Feel free to explore the sections that are most relevant to you. As always, we appreciate your support and patience! :handshake:
