Maker Tuesday | Snapmaker U1 Feature Highlights and Discussion
The feature video of Snapmaker U1 is here! Watch the video:
Visit the pre-launch page and leave your email to get updates as we unlock more features: Snapmaker U1 Color 3D Printer
Meet the next-generation multi-color and multi-material 3D printer built for fast speed, efficiency, and creativity.
What excites you the most?
  • The speed?
  • The color potential?
  • Or the multi-material options?
Let us know in the comments!
Kinda light on deets. Not even build plate size that I could see?
270x270. High is unknown for me.
You could see at its first YouTube announcement.
Honestly, I am excited about this. I hope the price point is right for the average consumer ~$1000 - $1300 so it’s comparable to the J1, Bamboo Labs with AMS, Qudi with box, etc. I have sold all my 3-in-1 printers at this point in favor of dedicated machines, and I was working on a Voron 2.4 with stealth-changer, but this could easily put that project on hold. I do have several questions:
  1. What is the maximum hotend temperature? I’m not a multi-color guy, but I want to print high temperature filament with support more reliably, and this would be a game changer if it could reach 350C.
  2. What is the hotend like? V6 nozzles? Whole hotend and nozzle combo like the J1 and bamboo? Can I put a diamondback nozzle on here and print ABS-GF10 for days without stopping. Actually, a collaboration with Microswiss for Flowtech or E3D with their Revo would be incredible for no-leak nozzle changes. High-flow nozzles from the beginning would be great too.
  3. Is the hot end all metal this time?
  4. Are the dive gears the same size as the ones in the Artisan?
  5. Is there enough part cooling to sustain the ~500mm/s speeds when printing PLA?
  6. Is the chamber heated? If so, is it active, or passive (bed heating).
  7. From the video, it looks like 270mm^3 is that accurate?
  8. What kind of bed probe does this have? Is it auto calibrating? Optical sensor, inductive sensor, load cell? It said eddy current sensor for alignment of the toolheads, and I assume that’s for the bed too, but I want to be sure.
  9. Is this running Klipper or Marlin?
  10. Does this use an onboard accelerometer for input shaping or is it like the 2.0 where you print the tower and select the best lines?
  11. Does this have a built in Lidar sensor for linear advance calibration?
  12. Does this use a filament buffer for loading through a long path or is the extruder pulling material right from the spool?
  13. Does this include clog detection or just break/runnout detection?
  14. How are the VFAs? The only thing keeping me from buying a Prusa CoreOne right now is the surface quality issues. Does this use 1.5mm pitch belts to combat this? 0.9 deg steppers?
  15. How is maintenance on this machine? Belts needing to be tensioned often? Re calibrating the x/y/z offset on the toolheads?
I definitely want my next printer to be a tool and not a project. As cliche as it is to say, it needs to “just work”. I’ll be keeping a close eye on the reveal, and I hope to keep a snapmaker machine around.
Edit:
  1. Does this have a way to use filament dryers, or do the mounts on the side of the machine need to be used for proper function?
  2. Does this mean the discontinuation of the J1? It looks like the Ray is out of stock on the US store, and not being restocked? Can we assume you’ll sunset some projects to make room for this?
  3. Is the enclosure all aluminum or steel? Are the doors acrylic (plastic) or glass?
  4. Can I make use of different sized nozzles?
  5. Does this support wipe to infil so I can avoid a wipe tower?
Looks really good!
Like @Wyphorn said, looks like it’s 270x270x270 at least from what I can tell from the video posted. I took a screen shot where you can kind of read it on the print bed where it says “Build Volume”.
I’m hoping there is a way to enclose the filaments on the sides and cover the top.
I print in PETG and live in Florida so I need to make sure the filament is a dry as possible!
Sorry. This shouldnt be an answer to conshus.
Wasnt there some XTool lettering on the rumor images? Is this a coop?
Do you really want to finance this with Kickstarter or why there are Kickstarter references?
Yep, will launch on Kickstarter - see e.g. here: About the Snapmaker U1 category
@ rtrski @ Wyphorn
Yes, U1 offers a build volume of 270 × 270 × 270 mm.
Thank you for your interest. Please note that the earlier information was not officially announced. For the most accurate and up-to-date details, please refer to our official announcements.
Regarding your question about Kickstarter, yes, the U1 will be launching on Kickstarter.
Thank you for your interest and support.
Here is a collection of some frequently asked questions about the U1 that we have put together so far. Please feel free to take a look:
https://support.snapmaker.com/hc/en-us/articles/33344279396759-FAQ-for-Snapmaker-U1-3D-Printer
Is there any chance that you use your new knowledge to get a really good printhead for 2.0/ Artisan?
Or do you stopped all Hardware developments on your “old” machines? And no, i do not need any fance multicolor stuff, just a good single extruder.
Thank you for the information Sherry. I appreciate it, and I look forward to seeing more in the future. Have you sent out review units? I’d love to see some printers in the hands of experienced reviewers for this launch.
Very excited about this as I was trying to find the time to build myself a Voron! I had an idea for a modification to minimise wastage from priming after extruder changes (from the videos it looks like you have not managed to eliminate the prime tower, though it is possible I have misinterpreted). I am offering this idea open source to anyone who wants to do the development as I probably will not find the time myself.
The fundamental idea is that by priming onto a small auxiliary bed at fixed height we could avoid having to lay down every layer of a prime tower with enough area for the layer with the most extruder changes (so for most prints, most of the material in the prime tower is simply support material for the layers above). The second part of the idea is that instead of a flat priming bed a roller bed would be used positioned under the row of extruders in the parked position. After the head was coupled up, but before it was moved from the parked position, the prime extrusion would be made with the extruder stationary and the roller bed rotating under it. There would be a scraper bar to knock the plastic off the roller bed just before it came back round to the extruder position.
I do not know if it is still early enough in the development to consider this idea (assuming there still is some wastage to be saved), or if it could be considered as a later add-on.
Hi, Can I use ABS or other materials that need enclosure?
I think It is a little bit hard to enclosed the top of U1.
Hello, thank you for your interest. We have a dedicated team managing the review units and coordinating related content. It might take a little while before there’s more progress and reviews are published.
U1 is compatible with common 1.75 mm filament materials, including:
PLA, PETG, TPU, PVA, PET: Ideal
ABS, ASA: Ideal
PA, PC: Capable
We haven’t stopped supporting our existing product lines like the Snapmaker 2.0 and Artisan. While there are currently no plans to release a new single extruder for these models, we truly appreciate your feedback and will share it with our team. If you experience any issues with your 3D printing module, please feel free to reach out to our technical support team at support@snapmaker.com. We are always here to help.
Really looking forward to this one. Already have questions though! I’m very curious the sensors used for the calibration.
  1. Maybe most important: X/Y/Z offset per tool? Snapmaker did very well on x/y offset for the J1. How will it work on the U1? Is this “one-click” offset calibration? We see auto bed leveling, but is there also a Z offset per tool?
  2. Accelerometer based input shaping, I guess?
  3. Pressure advance set per tool based on the filament used/profile? Any special flow sensors or is it print-to-test?
  4. The spool hub looks like it’s meant only for standard spool hub diameter. Will it work with undersized spools? (I have also have a variety of sample 250g spools that have a smaller inner diameter.)
(On #3, I personally don’t mind setting and forgetting pressure advance once for a type of filament, but flow sensing would be nice.)
Is there going to be a top for the unit? Clear plastic dome produce to enclose the top to keep the heat in for HT filaments and bed temps.? Flip open to work on the top but enclose it to keep it clean and warm when needed…
