Snapmaker U1 Add-ons Update
We’re adding new add-ons for U1 on Kickstarter:
  • Hardened Steel Hot End Bundle (0.2 / 0.4 / 0.6 / 0.8 mm)
    • Note: Different sizes cannot be used in the same print.
  • PEI Steel Plate (Smooth Surface)
  • Steel Build Plate (Carbon-Fiber Texture Surface)
Check the details on U1 Kickstarter page→
I’m consufed, what’s the difference between PEI Steel Plate (Smooth Surface) and PEI Steel Sheet?
Why is one called ‘Plate’ and the other ‘Sheet’? :thinking:
Not sure why the change in language. But the difference between the included one and the “smooth surface” plate is only the texture.
The smooth PEI sheet provides a very nice matte finish to the bottom of prints. Though I would note, adhesion may differ depending on material. And to be careful not to scratch smooth or carbon-fiber textured sheets, as any scratches on those will be more obvious if transferred to a print (versus a normal, coarse sheet).
Thank you for your feedback and for pointing this out. We will update the wording when the pre-order goes live on our store and unify it as PEI Steel Plate.
延保适用用中国用户吗?
中国用户也是可以的哈~ :blush:
How to Manage Add-ons for Your Pledge
Hi everyone, If you want to update your add-ons for your U1 pledge, here are some helpful guides:
  • On PC:
  • On Android:
  • On iPhone:
Important note: We will send you a backer survey before shipping to confirm your delivery address. During that process, you can still add any desired add-ons to your order. The price of any add-ons purchased through the survey will be the same as the current add-on prices (except for the Snapmaker Care 1-Year Plan for U1).
