Hi, hope this does not sound like a rant, and if anyone has any suggestions, tips I would be grateful to hear them
I currently have an A350 with the 10W laser upgrade and have been using it very successfully for the past year, engraving coasters, chopping boards etc. I thought I would treat myself to an “upgraded” machine so hence I ordered a 40W Ray with and enclosure.
Machine and enclosure arrived and were duly assembled. Everything went well and both the quality of the equipment and instructions were what I had come to expect from Snapmaker. Connected up the machine to my computer and loaded the latest version of Luban
I then went on to run some tests, this is when things went seriously downhill, I stupidly expected things to be similar to the A350 with a dot indicating the centre of the beam. I was presented with the red cross-hairs, assuming that the intersection of the cross-hairs was the centre on the beam.
I positioned the centre of the supplied test board on the intersection of the cross-hairs and started the job only to discover that this is not the case; the intersection of the cross-hairs is offset from the beam by approximately 22mm in the X Axis and 2mm in the Y Axis. WHAT IS THE POINT OF THE CROSS-HAIRS?. This resulted in the test piece being cut partially off the test board. It is nearly impossible to engrave things in a tight space, making the main reason for buying the “upgraded” unit pointless.
As mentioned previously I do engraving on wooden (Bamboo, Acadia wood, Pine, Beech etc.) boards and use 40 – 50 % of the laser power with a speed of 600mm/min, this gives me the depth and colour of image I need. I have tried numerous samples and test grids and have yet to get anything comparable in colour or depth.
If I could send this unit back I would, but the returns policy makes it impossible. I cannot and will not recommend this unit to anyone until these issues have been resolved
I am at my wits end and feel I have wasted nearly £1600 on something I can’t use. Any help would be much appreciated. If not up for sale she goes !!!
