I have a question on the mounting of the 3D print head. In this response picture 2 shows your print head is mounted on the bottom of the x axis module, while in the instruction it calls to mount in the middle of the bracket. Mounting the way it calls it out in the instructions requires the x axis module to go lower on the z axis module which seems to cause a more jerky motion on the z response on 3 D print on the initial part of the build. Would mounting the head on the bottom of the bracket fix this?
It’s only mounted on the bottom bracket temporarily so he can access the screw to adjust the sensor.
If you’re having problems with the motion being jerky than you probably have excessive play in the brackets for your linear rails or some other problem with your z-rails. The motion should be consistent no matter what the height of your x-axis.
@xchrisd and I troubleshooted it with @Steener in a separate thread, the converters were swapped around and it started working.
Back to the topic at hand, @sdj544 the IR sensor conversion that @stewl wrote up is working wonders, I think if Snapmaker put an IR sensor on it the print head gouging would be greatly reduced if not completely eliminated. The stock z probe I never had come loose, but the fact that it can and does is a major problem point. The IR sensor is great for detecting the actual surface unlike induction. Although black surfaces are supposed to be the weak point of IR sensors, I tested it with the pei sheet and it still saw it.
The firmware has been updated to
Snapmaker2_V1.14.2
My calibration procedure breaks down at point 5 and tries to push the nozzle into the plate until the bed bends and the vertical actuators skip and fail
The best I can figure is that the proximity sensor is marginal when at point 5 ( the proximity sensor hangs over and off the build plate ) Perhaps the Snap maker people can verify.
for example, this shows where the proximity sensor is located
When ever I try to find information on the proximity sensor on any Snap maker official website or forum I get the following
oops
You’re not authorized to access this page
For now my snapmaker 2 A350 is an expensive brick.
The proximity sensor is the black cube in the back right. So it’s still well on the bed in your video. There is a red led that should go on when you’re holding something metal under it.
Check this thread for official troubleshooting guide:
Double check your cabling and assembly. Make sure y-axis rails are centered on the bed and not hanging over.
Many thanks . Ive establised the proximity sensor works by putting the Snapmaker scraper knife they supply ( metal blade) near the sensor while its half way down and that stops the calibrate procedure. The nozzle then is seeking the print bed in mid air.
At contact point 5 when the nozzle tries to gouge itself into the print bed . Ive now put a small 1" x 0.75" magnet under the print bed (it clings to one of the bolt heads)
That’s now solved the proximity sensor issue - the nozzle no longer tries to destroy the print bed.
So the issue has been a proximity sensor , sensitivity issue.
Its a component design issue when you consider - all pages relating to the proximity sensor have now been removed and the print heads are euphemistically “sold out” (removed)
until they find a solution for this. Try my solution - simply quick, effective and repeatable.
