Sep. 24: v3.9.0
  • Feature: Add “Object List” widget for 3D editor (#381)
  • Feature: Add system fonts support for text, remove font upload (#401)
  • Feature: Add object multiple selection support for 3D printing (#413)
  • Feature: Add WYSIWYG text edit, multi-line text is temporarily disabled (#401)
  • Feature: Add multi-select operation to editor (Laser & CNC) (#435)
  • Feature: Add .rpm package for Linux distros (#457)
  • Improvement: Disable model operations in process stage (#379)
  • Improvement: Change software landing page to 3D G-code generator (#391)
  • Improvement: Optimize CNC Relief mode tool path (#406)
  • Improvement: Optimize transformation panel in SVG editor (#416)
  • Fix: Fix duplicate shortcut (Ctrl + D) after undo operation (#381)
  • Fix: Fix some bugs of project saving (#401)
  • Fix: Fix wrong z_seam values in 3D print configuration (#409)
  • Fix: Fix progress bar missing occasionally when slicing big models (#411)
  • Fix: Fix several bugs of editor (path flip, size control, etc) (#414, #449, #456, #458)
  • Fix: Fix issues of Snapmaker Original door detection toggle (#421)
  • Fix: Fix dwell time unit for laser greyscale mode (#428)
  • Fix: Fix SVG numeric parsing (#430)
  • Fix: Fix parse of SVG to avoid extra parsed shapes (#433)
Snapmaker Luban for macOS
Snapmaker Luban for Windows 32-bit
Snapmaker Luban for Linux 64-bit
.deb package
.rpm package
.tar package
Snapmaker Luban for Linux 32-bit
.deb package
.rpm package
.tar package
Hint: To start Snapmaker Luban on Linux, you need to:
  • Add your user to group dialout: sudo usermod -aG dialout [your username]
  • Start executable: snapmaker-luban (.deb version) or ./snapmaker-luban (compressed version)
