When I open a project in Luban to send to my printer and select More settings then Luban stops working.
@MShaw48 Are you connected to the SM while you try to open „more settings“?
It doesn’t matter if I’m connected or not, I still get the same error.
Do you have the same issue with an small model, a calibration cube for example?
I can open files, save, export and print, etc. I just can’t access the “more settings” portion without it quitting.
This are the things I would do:
1. open Task Manager
To see how the Computer is performing while this issue.
2. run luban As administrator
(right click on luban icon…)
3. don’t use a full size screen
Make the window of luban small as possible. Sometimes a popup notification opens behind the screen and you couldn’t see it
4.reinstall luban
5. older version of luban
if you have the same issues after reinstalling luban, I would try to install an older version of luban
You can find them here:
[Snapmaker Luban Downloads and Updates]
None of the suggestions you made worked, however I was able to open it in my browser and get it working there.
Crazy… could you share your computer details?
Sre, if that will elp
@MShaw48, I experienced the same issues with Luban – I followed the steps in this Luban thread by @furnace2 and it solved the problems
Thanks, I’ll try that in the morning.
