Snapmaker enclosure gives horrible wifi connection
where is the wifi module located in the A350T? Since I have the enclosure, I constantly loose wifi connection or am not even able to connect at all. Before I had no issues at all.
Besides that, I think the software has bugs. If I lost the connection and reconnect, the screen on the A350T shows that I am connected (Disconnect button in the bottom) but Luban says “Screen Authorization needed, confirm the Wi-Fi connection request on the Touchscreen” but there never is a request.
The bad thing about that is, that after losing the connection again, the machine just gives a pop up where I should confirm that the connection was lost and stop the print. I can’t just close this window and therefore can’t interact with the machine/change print settings for the entire print, that is really bad.
Thanks in advance.
Regards
