Since Today i got a Problem with my Snapmaker 2.0 A350T (Only 1 Week old) all Prints went fine so far and since today i got extreme Layer shifting and i think the y-Achsis got significant louder…
if also tried recalibration, slower Printing, other Files… nothing helped.
Update: I checked every Bolt and so on, everything is snuckly in. and i printed a realy slow print ~20mm/s and still horrible shifting but a bit less then with normal speed.
Printed the test Cupe with 1 Linear Module Build in (other Linear Module also Plugged in controler but not Build in the Printer so it went true the air) → Print went nice… so i tried the same with the other Linear Module → print went also nice, but when both Linear Modules are build in it shifts again…
Hi Tiefbau, could you please provide the ticket number? I’ve asked my colleague but they only found two emails from you to the info and none to the support.
