Snapmaker A350 printing stops / freezes at 2/3
HI,
since a few weeks month 3D printing got really a pain. First my whole printing head got messed up after a regular print. Everything melted away…
It was exchanged by snapmaker (thank you) but still 3D printing got worst. I used to print dozens of items without any problems (except of the usual things). Now only 30% of my prints come out usable.
7 out of 10 prints my snapmaker freezes at 2/3 of the print. It just stops with minimnal filament around the nozzle. The firmware / machine seems to be frozen
Iam currently printing again and will attach a picture asap
Sometimes the same gcode works after a few restarts and calibrations.
Anyone else has / had this experience and may tell me what Iam doing wrong ?
How do you print?
  • USB-thumb drive
  • WiFi with luban
  • WiFi with other slicer
  • USB to serial connection (which Slicer.)
What is displayed on the touchscreen when the print stops?
It seems you are printing from your pc/Mac and the communication got stopped.
This could because of a bad connection or standby-mode.
After the next fail, upload the logs to the forum pls.
hi,
usb
display shows x% regular printing screen but system is frozen
Which slicer did you use?
Uploading the logs is the next step.
Maybe your gcode or thumb-drive is corrupted (You meant the drive with usb, no serial connection, right?)
Iam using Luban as slicer
Iam a new user and not allowed to upload my log… oh come on wtf. Iam enrolled since snapmaker 1 “Update, I uploaded the log files”
Following some log entries from today before it crashed AGAIN.
I have SC_247.log
1593959087649,2020.07.05 14:24:47.649,INFO,SC,line 383000: G1 X102.053 Y167.163 E2783.762
1593959127393,2020.07.05 14:25:27.393,ERROR,SC,java.lang.ArrayIndexOutOfBoundsException: length=20; index=20
1593959127395,2020.07.05 14:25:27.395,ERROR,SC,	at com.snapmaker.fabscreen.data.print.OnAirGcodeModifier.override(OnAirGcodeModifier.java:233)
1593959127396,2020.07.05 14:25:27.396,ERROR,SC,	at com.snapmaker.fabscreen.data.print.PrintController.doNext(PrintController.java:406)
1593959127400,2020.07.05 14:25:27.400,ERROR,SC,	at com.snapmaker.fabscreen.data.print.PrintController.lambda$prepare$0$PrintController(PrintController.java:94)
1593959127402,2020.07.05 14:25:27.402,ERROR,SC,	at com.snapmaker.fabscreen.data.print.-$$Lambda$PrintController$CcwFAhN3t-5331zLWkZAmM0L3GQ.accept(lambda)
1593959127403,2020.07.05 14:25:27.403,ERROR,SC,	at io.reactivex.internal.observers.LambdaObserver.onNext(LambdaObserver.java:63)
1593959127404,2020.07.05 14:25:27.404,ERROR,SC,	at io.reactivex.internal.operators.observable.ObservableObserveOn$ObserveOnObserver.drainNormal(ObservableObserveOn.java:201)
1593959127405,2020.07.05 14:25:27.405,ERROR,SC,	at io.reactivex.internal.operators.observable.ObservableObserveOn$ObserveOnObserver.run(ObservableObserveOn.java:255)
1593959127406,2020.07.05 14:25:27.406,ERROR,SC,	at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66)
1593959127410,2020.07.05 14:25:27.410,ERROR,SC,	at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57)
1593959127412,2020.07.05 14:25:27.412,ERROR,SC,	at java.util.concurrent.FutureTask.run(FutureTask.java:237)
1593959127413,2020.07.05 14:25:27.413,ERROR,SC,	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:272)
1593959127414,2020.07.05 14:25:27.414,ERROR,SC,	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
1593959127415,2020.07.05 14:25:27.415,ERROR,SC,	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
1593959127416,2020.07.05 14:25:27.416,ERROR,SC,	at java.lang.Thread.run(Thread.java:761)
1593959154112,2020.07.05 14:25:54.112,WARN,SC,No reply for 26715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
���ԁ�"TE {SH�.�fI˯�)b�g<��I��j-�"ڧ}s��)
1593959164110,2020.07.05 14:26:04.110,WARN,SC,No reply for 36717 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959174106,2020.07.05 14:26:14.106,WARN,SC,No reply for 46715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959184106,2020.07.05 14:26:24.106,WARN,SC,No reply for 56715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959194110,2020.07.05 14:26:34.110,WARN,SC,No reply for 66717 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959204106,2020.07.05 14:26:44.106,WARN,SC,No reply for 76715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959214110,2020.07.05 14:26:54.110,WARN,SC,No reply for 86716 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959224106,2020.07.05 14:27:04.106,WARN,SC,No reply for 96715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959234108,2020.07.05 14:27:14.108,WARN,SC,No reply for 106715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959244109,2020.07.05 14:27:24.109,WARN,SC,No reply for 116716 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959254109,2020.07.05 14:27:34.109,WARN,SC,No reply for 126717 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959264109,2020.07.05 14:27:44.109,WARN,SC,No reply for 136717 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959274106,2020.07.05 14:27:54.106,WARN,SC,No reply for 146715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959284109,2020.07.05 14:28:04.109,WARN,SC,No reply for 156717 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959294112,2020.07.05 14:28:14.112,WARN,SC,No reply for 166718 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959304110,2020.07.05 14:28:24.110,WARN,SC,No reply for 176718 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959314109,2020.07.05 14:28:34.109,WARN,SC,No reply for 186717 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959324106,2020.07.05 14:28:44.106,WARN,SC,No reply for 196715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959334109,2020.07.05 14:28:54.109,WARN,SC,No reply for 206715 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
1593959344109,2020.07.05 14:29:04.109,WARN,SC,No reply for 216717 ms since last response (#383774: ��Aow�?2��g�Ձ�Uoc[������9% *rVe��S5	��,��Q�
FW_3.LOg the last day
1593942991694,2020.07.05 09:56:31.694,INFO,SC-FW,SC req save data of leveling
1593942991696,2020.07.05 09:56:31.696,INFO,SC-FW,nozzle height: 1.103
1593942991821,2020.07.05 09:56:31.821,INFO,SC-FW,new leveling data:
1593942991823,2020.07.05 09:56:31.823,INFO,SC-FW,6.22
1593942991824,2020.07.05 09:56:31.824,INFO,SC-FW,6.37
1593942991826,2020.07.05 09:56:31.826,INFO,SC-FW,6.42
1593942991829,2020.07.05 09:56:31.829,INFO,SC-FW,6.55
1593942991832,2020.07.05 09:56:31.832,INFO,SC-FW,6.61
1593942991836,2020.07.05 09:56:31.836,INFO,SC-FW,Empty/NULL log message
1593942991839,2020.07.05 09:56:31.839,INFO,SC-FW,6.54
1593942991843,2020.07.05 09:56:31.843,INFO,SC-FW,6.79
1593942991846,2020.07.05 09:56:31.846,INFO,SC-FW,6.79
1593942991849,2020.07.05 09:56:31.849,INFO,SC-FW,7.04
1593942991850,2020.07.05 09:56:31.850,INFO,SC-FW,6.99
1593942991851,2020.07.05 09:56:31.851,INFO,SC-FW,Empty/NULL log message
1593942991852,2020.07.05 09:56:31.852,INFO,SC-FW,6.81
1593942991853,2020.07.05 09:56:31.853,INFO,SC-FW,7.02
1593942991855,2020.07.05 09:56:31.855,INFO,SC-FW,7.00
1593942991858,2020.07.05 09:56:31.858,INFO,SC-FW,7.21
1593942991859,2020.07.05 09:56:31.859,INFO,SC-FW,7.19
1593942991860,2020.07.05 09:56:31.860,INFO,SC-FW,Empty/NULL log message
1593942991861,2020.07.05 09:56:31.861,INFO,SC-FW,7.14
1593942991866,2020.07.05 09:56:31.866,INFO,SC-FW,7.20
1593942991867,2020.07.05 09:56:31.867,INFO,SC-FW,7.06
1593942991868,2020.07.05 09:56:31.868,INFO,SC-FW,7.28
1593942991869,2020.07.05 09:56:31.869,INFO,SC-FW,7.23
1593942991871,2020.07.05 09:56:31.871,INFO,SC-FW,Empty/NULL log message
1593942991872,2020.07.05 09:56:31.872,INFO,SC-FW,6.83
1593942991873,2020.07.05 09:56:31.873,INFO,SC-FW,7.08
1593942991874,2020.07.05 09:56:31.874,INFO,SC-FW,6.95
1593942991875,2020.07.05 09:56:31.875,INFO,SC-FW,7.10
1593942991876,2020.07.05 09:56:31.876,INFO,SC-FW,7.22
1593942991880,2020.07.05 09:56:31.880,INFO,SC-FW,Empty/NULL log message
1593942991881,2020.07.05 09:56:31.881,INFO,SC-FW,leveling ON
1593943003889,2020.07.05 09:56:43.889,INFO,SC-FW,SC get env: 4
1593943003891,2020.07.05 09:56:43.891,INFO,SC-FW,live z offset: 0.000
1593943004120,2020.07.05 09:56:44.120,INFO,SC-FW,SC req START work
1593943004122,2020.07.05 09:56:44.122,INFO,SC-FW,SC req -> Sucess
1593943004281,2020.07.05 09:56:44.281,INFO,SC-FW,new E target temp: 220
1593943004304,2020.07.05 09:56:44.304,INFO,SC-FW,new B target temp: 70
1593943004319,2020.07.05 09:56:44.319,INFO,SC-FW,leveling OFF
1593943040755,2020.07.05 09:57:20.755,INFO,SC-FW,leveling ON
1593943040759,2020.07.05 09:57:20.759,INFO,SC-FW,Apply Z offset: 0.00
1593943046692,2020.07.05 09:57:26.692,INFO,SC-FW,new E target temp: 220
1593943153938,2020.07.05 09:59:13.938,INFO,SC-FW,new B target temp: 70
1593943570040,2020.07.05 10:06:10.040,INFO,SC-FW,new E target temp: 220
1593943571204,2020.07.05 10:06:11.204,INFO,SC-FW,new B target temp: 65
37994,1970.01.01 00:00:37.994,INFO,SC-FW,SC req Exception
37997,1970.01.01 00:00:37.997,INFO,SC-FW,SC req enclosure sta
-_-FW_3.rar (496.8 KB)
It seems there is no response from usb.
Any ideas @Edwin @JKC20?
I would suggest to try another thumb drive.
i have 3 thumb drives, all behave the same
iam now trying to print via wifi / transfer the same file lets look what happens
it is the USB Port on the snapmaker.
I extended wifi range and submitted the gcode to the machine. Now the prints work as intended
Thank you !
Still shouldnt happen
You should forward this to the support
Support@snapmaker.com
Hi @realfire
Sorry for the late reply.
It seems there’s a lot of garbage in the G-code file. Please send me the file that you failed to print.
Does this issue happen every file you print?
Looking forward to your reply.
Best regards
Hi Edwin,
no only happens when iam using USB Port. The same gcode works fine when sent via WIFI.
No not every file some prints worked out
Hi Realfire,
Previously, some users used a USB extension cable with the USB thumb and then started to print, which would cause the screen to fail to read the file and stop printing.
Best regards
HI,
no extension cable was used, three different usb sticks. All having the same issues.
Please note two month ago the same USB sticks worked like charm
Kind regards
Christian Weis
Does your USB contain only your current project or is there more data on it?
Also gcode from past prints.
Maybe you can try to clear your USB and put only your current project on it. Other devices sometimes have problems with fragmented files.
I formatted it and its already printing. Still strange the same occurs on different usb sticks
If you’re using wireless on a pc, windows is able to shut the connection off if it thinks the connection is idling.
Open the adapter dialog, properties, and then Configuration. Find the Power tab and uncheck the first box.
after I formated the usb it works. So it seems all three sticks have been messed up -_- still strange
At least it works again :+1:t2:
