Hello.
Who can help me with the STL file of the spiral vase I can’t find it for my dual extruder.
Thanks in advance
Maybe it’s in the Luban examples?
On the Luban main screen there are various examples available.
Currently on vacation so no PC here
Thanks for your answer but that is not a stl file but a gcode and that does not work with the dual extruder that I only have from there .
but thanks.
Greetings William
I don’t see that exact vase on Thingiverse, but they have many others.
Just remember to change your setting in Model Structure > Model Structure Type from Normal to Vase. Obviously that only works with vases that don’t have holes in the walls. I believe this setting is why Luban ships with the GCode instead of a Model.
Thanks for your answer .Top ![]()
On a side note, remember to turn off vase mode when you do other models, as you start to get strange results…
