Hello Brian, that’s a great trick to replace the nozzle, shall definitely try, however may I request some more information on availability of nozzles on Amazon. Also I am still to try stainless steel and carbon fiber nozzles. Can you also suggest about the temperature sensor which is in the hot end assembly, it is normally just placed in the assembly is there any any other way some one had tried to fix it.
Hello , there are various nozzles available on Amazon, which has different nozzles with 0.2 to 0.5 dia , so is there any chart for selecting which one for which quality or speed of printing, which size do you recommend for general use.
.4mm is the standard. .6 is good for wood filament. smaller is good for finer detail
however, luban doesnt support anything but .4mm
