Snapmaker 2.0 A350 Modifications
Here is my list of modifications for the Snapmaker 2.0 A350 to make it a virtually flawless machine and significantly increase it’s reliability. Most are related to 3D printing, but many serve multi-purpose across the 3 different machine functions. I originally posted this on the Facebook group, and the admins there requested that I also post it to the forum so that it is visible to those who may not have Facebook. Photos of each mod are at the end of the list and are in the same order as the list. I am more than happy to answer any questions you may have. Big thanks to all of the creators who originally designed these; they have made a HUGE difference in the quality-of-life of the machine and in the quality of its project outputs.
Fysetc Powder-Coated PEI Print Sheet - https://a.co/d/ez7xSys
CR-6 Bi-Metal Heatbreak Mod - https://forum.snapmaker.com/t/hot-end-clogs-the-how-why/30376?u=mxbrnr
MK8 Nickle-Plated Copper Nozzle - https://a.co/d/hHw2hLD
CNC Bracing Mod - https://forum.snapmaker.com/t/cnc-bracing-for-added-rigidity-other-mods/29444?u=mxbrnr
SBR16 Y-Axis Linear Guide Rail Mod - https://forum.snapmaker.com/t/a350-linear-guide-rail-mod/18853?u=mxbrnr
Toolhead Bowden Tube Coupler Adapter - https://www.thingiverse.com/thing:4763024
PSU Gantry Mount - https://www.thingiverse.com/thing:4809905
Universal Filament Spool Holder - https://www.thingiverse.com/thing:4876840
Z-Axis Filament Tube Guide (Z Roller Brace Compatible) - https://www.thingiverse.com/thing:6587881
X-Axis Cable Guide and Chain Mount (mirror for Roller Brace Mod Compatibility) - https://www.thingiverse.com/thing:4763757
X/Y-Axes Cable Chain Links - https://www.thingiverse.com/thing:5241817
Controller Cable Clamps - https://www.thingiverse.com/thing:4111866
Heated Bed Cable Chain Mount & Strain Relief - https://www.thingiverse.com/thing:5241817
Squash Ball Anti-Vibration Base Feet - https://www.thingiverse.com/thing:5919296
“Klicky” ABL Probe - https://forum.snapmaker.com/t/klicky-probe-bed-leveling-on-anything-stealth-mod-for-single-extruder/32229?u=mxbrnr
5015 Part Cooling Fan Mod - https://forum.snapmaker.com/t/3dp-part-cooling-fan-5015-replacement-for-gen-1-extruder/10038/341?u=mxbrnr
Nozzle Brush - https://www.thingiverse.com/thing:6588176
A klicky probe!
That is a nice set of links, thank you for sharing! I still trying to figure out how to combine quickswap and sbr16 rails =)
My pleasure!
Yes, the klicky probe is a HUGE improvement, at least in my case. I would have to say the Top 5 mods to seriously consider as must-haves are:
  • Klicky Probe
  • All-Metal Heatbreak
  • 5015 Fan
  • SBR16 Rails
  • Cable Chains, Strain Relief, Bowden Tube Coupler (I kind of consider all of these in the same category
The quality-of-life improvements to capability and reliability that those provide is just unmatched.
With all the mods, did you try the High Speed beta firmware?
I have not, because…I have actually been running the standard firmware with the same speeds and accels as the high speed Vibration Compensation firmware, and have been getting better quality because the prints are not suffering from the detail smoothing that comes with the VC firmware’s input shaping algorithms.
I am reading this post essentially as “you need to invest two Bambu Labs worth in time to make this a halfway reliable 2021 tech printer”.
Switched a year ago to Bambu and never looked back. Still have my Snapmaker, mostly collecting dust, sometimes used for some small CNC jobs, but certainly not as a 3D printer after enjoying the hassle-free no-mods no-tinkering just-productive Bambu experience.
Snapmaker and Bambu Lab each seek to fill a very different segment of the market from each other. It’s like trying to compare a Honda Civic to a Ford truck; they are really not comparable, the only real similarity is that they are both automobiles. If all you need is 3D printing, then yes, a machine specifically designed for that sole purpose will be better. For those who need or prefer the 3-in-1 and modular design of the Snapmaker, these modifications will help them to get the most they can out of the machine.
Thanks for sharing this. I just built my A350 and intend on using most of these mods.
Question, does the antivibration mod work with the enclosure footings?
Also, any recommendations for the type of brush to use for the head cleaner?
The brush is linked in the remixed from:
https://www.thingiverse.com/thing:6587991
No clue about the enclosure. I don’t have one, and so did not design these around it. Their only purpose I cared about was to reduce noise from the vibrations transferring into the table/shelf.
You’ll be happy to know that it is compatible and works with the enclosure.
Has anyone done this with the dual extruder?
And does it still work correctly with it?
Hello,
will this help with first layer problem in dual exdurder ??
thank you
