Just assembled my new Snapmaker 2.0 250. I did a great test print of a scale figure. So now I’ve imported my second project into Luban as both an .obj and .stl.
When I generate the g-code, a big swath disappears through the center of the model. I’m trying to understand why. It happens whether or not I have supports, and regardless of the quality (fast, normal, high).
Is it something having to do with the model, or with the slicer, or both?
Here’s an .stl of the model. I tried getting Cura up and running, but it can’t find my Snapmaker, even when I enter the IP address. I thought I’d try to fix the model first, before moving to a different slicer. Varna Library_MJ_3D Print Model.stl (2.8 MB)
When I import it into cura it shows up as only 20mm tall.
In meshmixer if I try to make solid it implodes.
I’m not great with repairing or modifying in meshmixer, so someone else will have to chime in with a way to fix it.
If something is too thin for Luban (or almost any slicer) to be able to print, it just ignores it. That could be your problem here.
Thanks. It’s my model. Was made for rendering, not printing. I likely need to reconstruct it. Was hoping that with supports etc it would be sturdy enough to print. It’s the first thing I’ve tried to print. I’ll rebuild it in Rhino.
It’s been a while since I used a 3D printer (10 years or so) so trying to remember all the parameters—technology has changed since then as well.
