Sending GCODE from Snapmaker Luban to Artisan
Hey y’all,
I’m struggling to send gcode commands via Luban do the Artisan controller - I’m sure there is someone here to explain me what to do:
What do I have:
  • Luban 4.15.2
  • Artisan most recent firmware
  • Laser Module 20/40W
  • connection via Wifi or serial (USB)
What does work:
  • connecting with Luban to the controller
  • moving the tool head via the Jog dial buttons in “Control”
  • requesting “g” G-Command List and “m” M-Command List
  • using Pronterface to connect to the controller via the serial port, here all GCODE commands do work as intended (movement, air pump on, …)
What does not work:
  • using Luban to send any GCODE commands results just in an “ok” but nothing happens, no movement, no nothing
What do I need to do to have any reaction when sending gcode commands via the Luban console?
Thanks for your feedback,
André
Hi atze02
please also contact official support to log your issue. If anyone in the forum knows what’s going on, they’ll reply as well.
Support will reply to the email within two working days, and the user will receive the response.
