Why I cannot send the G-Code (loaded in Luban workspace ) generated in other software to the device. I have to copy to the fresh drive or connect via wifi to send it.
Interesting, never had problems like this.
Whats your file-ending?
May share your file here?
Whats your Luban version and operating system?
The file ending ? (I think CRLF) ,Windows generated..
Any file generated using ESTL Cam , I have this problem…
My Luban version is 4.15.0.
so, attached a file as example.
TDO-3.cnc (65.5 KB)
You have to use a post processor for doing cnc.
After correct generation the file ends in *.nc
I looked at your file but i am not sure about the first lines which are not uncommented.
Try it again by editing the file extension to .nc
Still the same issue,
I have changed it to LF and changed it to *.nc.
I also have removed the first (lines) which are not un-commented (I thought “(” is also considered a comment).
By the way, when we save the G-code from Luban, the extension suggested is *.cnc.
So, that is why I use cnc.
Form_1746122879107.cnc (13.4 KB)
I created a similar test and i am able to send it, may try?
You are connected over serial, this way no upload is possible.
Serial connection is like bypassing the touchscreen and directly streaming to the controller of your machine.
This way no upload is possible.
Hum, ok, maybe a feature for the future then!
Thanks for helping (understand the problem)!
