Running boundary
HI everyone, we have set up the laser engraving for the Snapmaker 2.0 and printed the box (freebie) no problem, however, when trying to use it to engrave a sign, it does not allow us to run the boundary. It does the camera calibration and lets us move the image I want to engrave on top in workspace, but when the laser is moving, it is way out of the boundary. Help please! Thanks,
You’ll probably find that the origin will be correct if you run the job directly in Luban. If you transfer the file to the machine to run the job from the touchscreen then you will need to jog the laser head to the work origin you want, usually front left and then set work origin. Many people have reported this issue but the Snapmaker team don’t seem to think its a problem. Very irritating.
