Rotary module is shifting with IR 2W laser
Today is the first time I use my rotary module with IR laser.
I was using the Luban software and test file (Lion).
I did some smaller things without problems.
Is there anybody having this problem?
What am I doin wrong?
Thanks in advance
Hey, welcome to the community.
If your rotary module is still under warranty I would suggest to ask support:
https://support.snapmaker.com/hc/en-us/requests/new
Here is a thread which could be of interest for you, there where a few posts about skipped steps because of belt tension or too fast movement speed of the rotary (b axis).
This morning I loosen the belt tension a bit.
And slow dawn the speed to 3500 mm/min instead of 4500 mm/min.
And now it looks fine.
Hoop it stays like this. :crossed_fingers:
Thanks for the help.
