I have transferred several files to the Snapmaker 2 via wifi, and then my computer crashed out and I lost the files on the computer. They are still on the Snapmaker. Is there any way to retrieve them from the Snapmaker onboard memory back to my computer?
You want to retrieve the gcode files?
Just poked around the machine, don’t have a direct usb line to it…
You’ll probably have to track down how to get into a developer mode and then use an external computer/usb cable/file explorer to find the correct files and copy them to your pc. On the bright side I know for a fact I saw something about developer mode on the forums before. On the other side I didn’t pay enough attention to it to tell you how.
Hopefully you can get this figured out.
Specifically, I want to get the speed from the files, so if I could view the gcode, that would be enough. I had them dialed in to the perfect speed for making the cut I wanted. I suppose I could run it and do the math, but I imagine being able to view or retrieve the files is something that will have value in more instances than just this one. I’ll look into the developer mode. Thanks!
