Hi, does anybody know where i can obtain a replacement steel strip for A350 in the UK. Really don’t want to buy another module just for the sake of a strip of steel.
Steve
Write an email to support@snapmaker.com , they could offer.
Or you can try and "fix"it yourself, see this post:
Hi wasn’t sure where to put this, but I have recently had a similar problem. I stuffed one of the metal covers.
Apparently can not buy as a parts, I find this a little odd.
Any way looked at options and made my own.
Used clear plastic laminating sheets, place two together inside each other and laminated in normal machine. The two gives a total of 4 thicknesses and add strength.
cut to 5/8 wide and longer than the metal strips by about 50mm. Punched holes to suit clamps and installed in usual…
