Redo a job without reset the work origin?
Hi there
I have to laser multiple large sheets, so i have to set the work origin 5cm down and 5 cm right.
Everythings works well but after complete, there is no button to just redo exact the same job/moves. I have to go trough the whole process (load file, set work origin etc.)
Is there a way to redo the same job over and over with a single start click?
Thx
You can either use machine coordinates to bypass using work coords entirely, or for your subsequent runs, start the job in Luban. Using Luban doesn’t reset the origin, which has caused headaches for other users on the opposite side. Just make sure to run your first locally to set the origin where you want.
