In laser mode the work origin somehow switched from the center of my work plate to the bottom left corner. Now I have to manually move it to the center for every burn. How do I reset the work origin home point to the center of the workspace?
You could try using G60/G61 (Save Current Position | Marlin Firmware), but ihni if SM supports those.
– edit –
Looks like the answer is no, not supported:
Have you tried using “set work origin” on the bottom left of luban?
Yes, that temporarily sets the work origin, just like when you do it on the touch screen. For the next print it is reset to the default off-center position,
Using the touchscreen will ALWAYS reset the home, it’s part of the subroutine when starting a file from the touchscreen. You have to bypass it either via USB or wifi. You can follow the guides for a repeatable origin and quick sending in the stickied guides thread.
