Purpose of Laser Initial Cutting height Offset?
Can someone explain to me the purpose of “Laser Initial Cutting Height Offset” in Luban’s Laser module? I was getting ready to use a laser test grid and in checking the parameters, noted that this feature was used for a few of the test points, but with no identifiable rationale?
I have the same question. Does anyone have an answer?
It’s likely for cutting thicker materials. Adjusting the focal height to cut through partway, then down to cut the rest of the way through to keep the power focused where it needs to be.
