Hello,
Since the new update, the generated G-code is no longer correct if you enter the material thickness manually when starting the program via Luban.
The laser gets to close to the object… i even hit a mounting screw because of that ![]()
Its still working fine with the automatic measurement with the red laser.
I got an Artisan and the 10 W Module.
Best regards, David
