I spent quite a bit of time trying to perfect a good box joint using my snapmaker A350. I was able to do this successfully by using outline mode in the toolpath. I actually built a really cool box with sliding panels.
All I did was create an SVG file, upload it and assign the toolpath. I have run into a bit of a problem when doing this though. In order to do outline mode, the SVG file must be 100% closed. I want to CNC an object that is not closed (think of creating an L pattern instead of a closed square). Because of this I can not use outline mode and have to use “On the Path”. I cant get on the line mode to work correctly, even when selecting the proper bit. The joints are just gapped too wide.
Does anyone have any suggestions on how to do this? I am using a basic graphic design vector program to generate the SVG, but i’m not sure that matters.
