Hello,
I already did CNC carvings in the past with my snapmaker and the Luban software and it worked. This is why I’m wondering what the problem is at the moment. I updated the software, so this is not the reason for my problem. It doesn´t work with both versions.
When I’m in the CNC mode and insert a .png file the software tells me I can do a relief, which is not what I want. I want to cut the snowflake out.
If I’m uploading a .svg file the software doesn’t show me any option to do a relief or cut it out. It only shows in the upper right corner, that I put a shape into it.
As I didn’t know what the problem is, I tried to put in a .dxf file what gets an even worse result! I can’t even see my design. But clearly there is something loaded, as it also shows a shape in the upper right corner.
Does anybody have an idea what the problem could be?
