Bonjour à tous, j’ai reçu ce jour le laser 40watts, après branchement et 1er démarrage, j’applique la procédure 4.2 Calibrage de la hauteur de la plate-forme, lorsque j’appuie sur démarrer rien ne ce passe.
Quelqu’un aurait il une solution ??
What’s your machine?
Did you calibrate from the machine touchscreen or Luban?
Did you update your machine firmware?
the machine is an A 350, luan is on the latest version, the firmware is the latest, the laser is recognized, I validate the security notes, I arrive on the Platform height calibration screen, I click on start and nothing happens
Please double check that your boosted toolhead cable is properly plugged in, there is a note on the controller plug side “Add-On” and “Tool-Head” (highest port).
thanks, it was something like cutting dust on the contact, it’s solved thank you very much for your help:+1:![]()
