I recently bought a Snapmaker 2.0 it performd great.
But now i mounted a 0.2mm nozzle on the hotend and runned a print with cura, and the print came out like swiss chees…
All in all the print was coming along but on the top surface it began to get a pretty god amount of holes.
Does someone now this problem and knows how to fix it?
(left side was printed with a 0.4mm nozzle and the right with a 0.2mm nozzle)
Calibrate your extruder with 0.2mm nozzle, to be sure you are not underextruded. After that I would suggest to print more top-layers to prevent such holes.
BTW, what’s your retraction settings? I would suggest you about 1mm to prevent filament grinding.
A dry-box and printing enclosure is in progress.
For my next print i definitely use a higher printing temperature, as well i will try to dry the filament.
The strange thing is: bottom, walls and infill came out great…
Thanks to all for the fast response.
I’ll give an update after my next try
Thanks guys it worked out great.
I raisd the temperature and added more layers on top and bottom and also gave it a little more infill.
I lowered the printing speed to 18mm/s
It’s great to this community around to help each other😁
