A350 snapmaker 2.0
quick swap
brace kit
Luban 4.13.0
firmware1.2.3 current
I would first try re-installing Luban, and re-installing the machine firmware via USB.
software / firmware refresh made no change to the issue.
Extruder calibration was already addressed.
Maybe you can try with this troubleshooting: Nozzzle can not be heated | Snapmaker Wiki
Share your gcode and export your logs.
I think your thermistor is faulty and causes a heat runaway error.
As @Zoe suggested, check out the link.
I had this problem to, I replaced the extruder and bingo it works again, thank you very much for your advice.
Exactly what I needed my friend! Thank you so much!!
