I give up.
I’ve used various recommendations from around the web to improve my overhangs, but it just doesn’t work.
Is there anyone of you who can print good overhangs at least up to 45 degrees and if so, please share his settings?
Best regards.
You print too hot or your part cooler is too low.
Improve your cooling or print temperature and see if it gets better.
Maybe this helps you for more understanding:
I find that a smaller layer height helps. I can print 50º at 0.2mm, and 60º at 0.1mm before it starts getting noodley.
Thank you, I will check this.
Best regards
