It’s probably been discussed already, but I couldn’t find any topic on the forum about this, so sorry if I missed it…
I’m trying to print a lamp cover that screws into a base. The thing should obviously be translucent, so I thought of vase mode, that would have the added benefit or removing seams.
This generates a problem however, in that I can’t do the whole thing in vase mode, I still need a “base” with the threaded section.
Here’s a section analysis of what I’m trying to achieve:
This model is actually 3 bodies, 1 for the very base (pink parts) to be printed in normal mode, a small part of the upper section (up to the line 10-15 millimeters above the base) just present for testing purposes in Spiral vase mode, then the rest of it upwards (Spiral vase mode as well).
I thought I would find “Spiral vase” option under “Quality” settings at object level, but I don’t, I only find it at global level, which will ruin the entire idea.
Is there a way to achieve what I’m trying to do here?
I’m also interested whether anyone has ideas on this. I have wanted to run certain parts of a vase-mode print very slowly, and tried using a modifier mesh to achieve that, but the vase mode rejected any attempt to add a modifier.
What I did was run two slices, one with the faster speed and the other slow, and then I spliced sections of the two G-Code files together in a text editor, using the layer count comments as the index (it still has layer counts, even in the spiral vase mode).
Trying this with splicing a vase-mode slice and a non-vase-mode slice looks trickier, with more to worry about than simply changing print speed (where, I found, the only difference was an F command each layer), but I think it’s worth a go. There will probably be a print defect at the join, but it might not be too bad.
Try a height modifier for the translucent part of the model. Specify a single perimeter wall and use random seams (with scarf). Tune the filament with the “Dynamic Flow Calibration” option in the print task menu to improve the layer lines.
DId some tests and looks promising (the Gcode way). I indeed just sliced both ways (“normal” and “vase”), then downloaded verbose g-code export and looked in Notepad for line 57 (where the transition is). The result didn’t work, I think because of an error in the model that created an overhang, so the spiral vase part couldn’t start properly, but
The printer accepted the Gcode
The print behavior and speed seemed correct
So I’ll modify the model and try again, whenever I fix my computer issues
