So when I check this option (which seems like it would save quite a bit of time), I no longer have the ability to generate G-Code. All the options below “Actions” are greyed out. Am I missing something?
Works fine for me in 3.13.1.
I have found a bug that seems to lock out generating g-code. Not sure why it happens yet. Just suddenly gets stuck and have to quit. Maybe it’s that and just seems to be the optimize path.
What version of Luban?
Same version: 3.13.1. Got to say it crashes a a lot, too.
When you say it works fine are you saying you can click on Optimize path and your “Generate G-code” button can still be selected?
Yes. I didn’t find that it immediately locked it up.
Not sure why yet it’s keeping the generate g-code and tool path buttons locked.
Seems like it forgets the link to the images. If I go back to editor the images end up having icons that look like it would on a program where you delete the file it’s referring to.
Need to play with it more.
Once again the new version of Luban introduces more bugs than it takes care of.
