I just updated Luban, (in the hope that it would generate gcode for 3d printing without randomly changing setting through the job!) but now it gets stuck generating the gcode. So now it’s even more useless!
Time to go try Cura I guess.
I just got a Snapmaker A250 and downloaded this same version and it stops ar 0.5%. What earlier version do you recommend?
Not sure I could recommend one. I haven’t had it for long either and I was having issues where I’d set a certain temperature or work speed, and for some reason it would just randomly change a few minutes into a job.
I’m now starting to play with cura, as people seem to say it’s a lot better than Luban.
Thank you. I may try an earlier version of Luban and report back.
Same problem myself - just recently installed current download on Win 7 machine.
