Valen
May 13, 2020, 4:48pm
1
HI!
My Snapmaker A350 is not working anymore. The nozzle does not heat up (change filament in menu). I exported the log and found the following line:
1589387330047,2020.05.13 16:28:50.047,ERROR,SC-FW,ERROR: System Fault[0x40000]! NOW cannot heat hotend!
Can anyone give me some hints whats broken?
Thanks!
Tone
May 13, 2020, 4:50pm
2
Have you tried swapping out the nozzle?
Valen
May 13, 2020, 4:54pm
3
Just tried that. But no change
Valen
May 13, 2020, 4:56pm
4
I have 3 sets of nozzles, none of them work anymore
Tone
May 13, 2020, 10:44pm
5
Probably the controller then. Time to contact support@snapmaker.com
JKC20
May 14, 2020, 6:31am
6
Please contact support for your issue.
Edwin
May 14, 2020, 10:05am
7
Please use the Y axes conversion cable to check if the toolhead cable(current one with the toolhead) is defective.
If the toolhead cable is defective, you can contact support@snapmaker.com for further help.
If the nozzle still cannot heat up with a new cable, the problem may lie in the printing module itself.
Please forward your result to support@snapmaker.com
Thank you
Valen
May 14, 2020, 7:33pm
8
I will check all connectors and then contact support. Thanks!
Valen
May 17, 2020, 10:38am
9
I think I found the problem, will have to contact support
(thats the printhead side)
Valen
June 21, 2020, 9:34am
10
I contacted support today. Got delayed by some stuff here
Edwin
June 26, 2020, 1:15pm
11
We will send you some new wires for replacement. In addition, here is a video for your reference.
Valen
June 26, 2020, 2:27pm
12
Thank you! That video is also really helpful.
I had the same problem today when replacing the hotend. I managed to push the pin back in. Should I nevertheless replace the cables?
I had the same issue on a 56 hour print job (44 hours in). Email sent to support.
Chris
Radiyox
January 20, 2021, 5:42am
15
I am having the same issue. After 20 minutes of print, it stopped and went to home position. Temp was back to room temp. Same error in the logs. Tried swapping cables and hotend to no avail and then noticed the same issue with the pin (mine was out completely. See picture.)
Valen
January 21, 2021, 3:20pm
16
I received a replacement cable some time ago but I didn’t have the time to replace it until recently. It works like a charm again (as expected). Thanks.
that probably could have been reinserted, although its very hard to explain if it doesnt want to stay where you have to pry at to fix it.
