I just started having a problem where the nozzle is does not heat up and it cools down during a print. The nozzle is alittle discolored but not bad. do I have to replace the nozzle? is there a video for this? I can not figure out how to connect the cable on the new nozzle.
There’s a 22 second video from Snapmaker on how to remove the nozzle. Installation is the reverse.
Found that link from here: https://support.snapmaker.com/hc/en-us/articles/1500000520102-What-should-I-do-if-the-Touchscreen-shows-a-30-nozzle-temp-
Yes, sounds like something has become disconnected or broken, replacing should fix. Check all the wires are fully inserted in the 4 pin connector, sometimes 1 will come out
Thank you for the quick response. would you believe the problem I could not figure out was trying to push the slide knob to open the door. guess that was so obvious, it was not explained in the video.
Keith
