Well I’ve had better days. This thing is rock solid. Like a brick. I tried to heat up the head to see if I could break it off but then I noticed that its encasing a wire. So I’ve got to be more gentile. I’m going to try a heat gun.
Alas, the Monster Blob is a not-uncommon rite of passage with the Snapmaker. Some people have succeeded in freeing one up with a heat gun, at the cost of a slightly warped fan shroud. If you can get enough of it off to pull out the hot end assembly, you have a chance. Best of luck.
And then, snapmaker 2.0 disaster part 4 - YouTube small fan is also unsalvaggeable. Snapmaker sent me a new m.dule but thefilament runout switch doesn’t work
