New Y-offset for 3D printing
Hello all.
I have printed and installed the following quick-snap solution and have a question. (snapmaker 2.0 quick tool changer by fips - Thingiverse).
After installation, the zero point and therefore also the lower and upper end points for the print bed are shifted, since the adapter means that the print head is no longer in the correct position as it was in the original state.
With the laser, I can define the working zero point for all three axes via the display and save it at least temporarily.
With 3D printing, I haven’t found a way to tell it that it can’t move so far forwards and that it could now move further backwards. In other words, the zero point for the y-axis must now be shifted, as the nozzle is now in the minus range as seen from 0 due to the adapter. How can I do this? Anyone have any ideas? I use cura.
