i just installed carefully my new printer, calibrated z-axis exactly how its described in the manual (i took an A4-paper and adjusted the nozzle so that im able to pull the paper with slight resistance and when i push its wrinkled).
After confirmation i shut down the machine at the power unit, 1h later i returned and tried to print my first module, imported an stl file to luban and started it from there. (printer is connected over WIFI)
The result you can see in the picture, so one side of my Print sheet is already destroyed. i hope the nozzle is fine…
What did i do wrong?
Right now im updating the firmware and will try again with again calibration and starting again with printing…
I am new to 3D printing, so at first i didnt understand if its filament or scratching the plate,… finaly when the groundplate was moved by the nozzle i started to think about aborting the print. Of course this took me some more seconds to shutdown.
greetings,
nordx
