After a bit of trying settings for
Yeti Tumbler ,Powder Coated. Came up with this setting, found very good
Power setting 10%, Speed 150, 1/2 diode on, no constant power, air assist on. Slow but sure. Will experiment further with a faster speed later
Artisan, Rotary, with 40 watt laser
I don’t know how your lines were so perfect. I did a test engraving using your settings on the 40W of 150mm/min @ 10% (first one was with air assist off and second was with it on)
I also tried 1000mm/min @ 10%, 3000mm/min @ 20%, and 2000mm/min @ 20%. It’s getting close but not quite perfect.
Hi all I am present doing another as my first (different name) same settings it is taking many hours to do. So will diffinatly look int speeding up process. Has anyone done any curved paited Yeti hip flasks front and back best to all Keiron
