First time using rotary module + engraving to engrave a Yeti tumbler. It turned out… okay. I set the X,Y,Z to be at the base of the yeti cup 0.1mm above. It seemed a little too close though even though the setup told me to touch the material. What can I do to improve?
Settings I used:
Method: Fill
Movement Mode: Line
Fill Interval: 0.1mm
Line Direction: Horizontal
Jog Speed: 3000mm/min
Work Speed: 1800mm/min
Laser Power: 100%
