I am hoping to use my snapmaker 2 as a multipen plotter. I know I can use the CNC function with a printed pen holder to use a single pen. If multiple pens were in the holder, this would require 2 additional functions (see Print color picture with multi-pen 2D plotter by 3D printer (Trick All you need to know ) - YouTube). How would I use the snapmaker to perform either of these:
Can a specific X-offset be applied to a layer? I don’t want to have to manually offset each color layer.
Can the snapmaker controller send g-code commands to anything other than the programmed toolheads? That is, could a g-code command to change pens be sent over the CAN bus without changing the snapmaker firmware? Alternatively, is the stepper wire connection available without changing the firmware? It has been about 20 years since I’ve programmed in C++ so I’m trying to avoid firmware changes.
Tim
