Filament Bowden Tube Holder 4 Tubes v3.stl (855.0 KB)
I used 4mm OD/3mm ID PTFE tubes and 4x PC4-M10 fitting connector to slide the PTFE filament tubing thru the filament holder extending maybe 2.5-3" past the opening to act as a flexible buffer for the filament when it gets pulled by the 3D print head (reduce shock loads).
Also created a small tube holder for the openings at the PrintDry Pro to keep the PTFE filament tube from sliding out:
PrintDryHole v1.stl (64.3 KB)
