Misundertood error
Does anyone knows how to fix this error?
Look at your slicer settings, for example raft first layer expansion, is it set to -1 ?
I take it this is about Snapmaker Orca rather than the U1? Or some other slicer??
My guess is the file was imported & the settings are for another printer. The error message tells you what settings are out of range, check them out.
No, bro, all variables are correct. I don’t get why it is giving this error
Thats true but I swap the conf. to snapmaker slacer even though still showing this error
Did you try to reset the configuration?
Maybe this:
So where have you imported this .3mf from? If it is from Bambu Studio, it needs a translation process – and there is one. Free browser converter for MakerWorld/Bambu → U1 (keeps colors + your print settings)
Where can I find this property?
It might help somebody explain what the problem is if you say where the .3mf came from. Without giving a full description, how can you expect proper help?
