MillMage compatibilty
Hello,
I installed the pre release of Millmage…. It looks so good…
However I have an issue with the jog… I can job the machine with the tool; however coordinates stay blank. In the console log I can see plenty of unknown command.
I used gbrl for setup.
Any idea what could be wrong?
Thanks
Hello. I’m afraid the problem is exactly the same as with Lightburn: To my knowledge, Snapmaker still refuses to make any effort to make the Artisan properly and safely compatible with Lightburn, without pitiful and dangerous tinkering that wastes a lot of time and takes unnecessary risks. Snapmaker’s suicidal attitude is starting to have very negative effects on its reputation: since I hardly use it anymore, I’m selling the Artisan I foolishly bought, trusting it, at a pittance, along with all the rotary lasers, etc., and of course, almost no one wants it! They’re aware of it and even suspicious of the J1! I’m always told, “I’m not going to buy an Artisan machine that’s virtually incompatible with Lightburn when the least cheap laser is compatible.” Very sad and not fair.
You are mostly right.
Its a absolute shame that Snapmaker is ignoring Artisan.
But you can get it working with Lightburn for Laser.
There are some good topics in this Forum which makes it workable thogh without camera (didnt even try Camera Setup).
I tested my Lightburn Settings in MillMage which sadly dosent work for me either.
You can jog around (Carefully. Endstops dont seem to work) but the Positions stay on 0/0/0
Oui, je parviens bien sûr à utiliser l’Artisan avec lightburn au prix de bricolages assez insupportables et surtout si on change souvent de laser, ce qui est mon cas car je passe fréquemment d’un laser bleu au 2w, du laser à plat au rotary etc. Cela m’oblige à faire des “acrobaties” insupportables et parfois dangereuses avec grbl et Marlin et cela ne permet pas de profiter des énormes possibilités entre autres en temps réel de Lightburn. Comme j’utilise un laser Neje qui est parfait pour certains travaux et tout à fait compatible avec Lightburn, je fais à contrecoeur pratiquement tous les travaux possibles avec ce laser dont le prix est très bas et le suivi vraiment bon : ce n’est vraiment pas normal. Quand je repasse sur l’Artisan, les vilaines astuces à utiliser obligatoirement et les impossibilités me font perdre un temps précieux et rendent les travaux pénibles et parfois dangereux surtout avec une machine qui m’a couté pas loin de 10 fois plus que le Neje. Avoir été trompé par des paroles rassurantes puis abandonné tout en ayant acheté TOUT ce qui pouvait être acheté, cela pour pouvoir faire du bon travail un peu “pointu” de qualité et de façon fiable et sécuritaire, me dégoute au plus haut point. J’utilise assez peu la cnc et l’impression 3D me suffit en l’état, j’aurais donc été comblé d’avoir une compatibilité GRBL qui peut tenir sur une carte de quelques centimètres carrés, hé bien non ! la direction Snapmaker ne veut rien faire.
Not everybody understand French here so I will reply in English….
First, for lightburn, Artisan works very well with lightburn. I used it for years. All laser modules have no problem. Same for Snapmaker 2.0. You must have not configured it properly. You have Marlin and GBRL supported.
Yes for CNC, I contacted support and they advised they are using Marlin for CNC and no plan to have GRBL.
I wrote to MillMage and asked them in Marlin support will come in the roadmap.
Some CNC commands are working with MillMage, for me the only missing one is the set work origin. I will try to set it via the console and then run the job. It might work.
Otherwise, you can move the head and start the spindle fine.
Cheers
Cheers
