Lightburn with Snapmaker Libary for rotary
Hello,
i try to use the Rotary Modul in Lightburn but it fail.
With Marlin i cant use the b-axis and with Snapmaker machine i can use the frame and it work the laser use all axis correct. But when i try to start the Laser Job then the laser is busy but it dont move or start the laser.
Did anyone know how i can fix it or got a machinelibary that work?
Thanks
Not sure if you used the search?
I searched for lightburn rotary and got at least two hits of @Skreelink s guides.
I have seen the guide but the code has to be worked on manually. I want to start the program directly via Lightburn without changing the code.
Is anyone currently having problems working with Snapmaker’s machine settings in Lightburn? Snapmaker can be controlled via Marlin but not via the Snapmaker settings in my LIghtburn i have Lightburn v1.7.02
Since Lightburn version 6.0.3, the program no longer works with “Snapmaker Merlin”. The laser no longer switched on, although the machine was working perfectly. I have now switched Lightburn to “grbl” and the problem has been resolved. I am currently using version 1.7.01. What doesn’t work is the home button. The solution is a macro with the code G28.
