Manual Calibration
Based on the link you provided, to get a bed of equivalent size for A350 (365x335mm) you would be spending approx 130 euros. If you are doing this just to get a level bed I would suggest you try printing on glass first, it will only cost you 5-10 euro in comparison to get a pane of float glass cut to that size.
To answer your question, if you plan on gluing the print sheet that came with the SM2 to the aluminium plate then you should be able to use the autolevelling feature as the print sheet has spring steel in the middle (ferrous and therefore picked up by the sensor)
I already have the print sheet from the link as well as aluminum board. So, if I understand right I will have to.
  • use manual calibration
    or
  • add something between the aluminum board and the sheet which contains ferrous
Correct?
https://www.amazon.de/Ferrofolie-selbstklebend-Magstick®-Eisenhaltige-unbeschichtet/dp/B07J5KN2SL/ref=sr_1_2?dchild=1&keywords=metallfolie&qid=1600380820&sr=8-2&th=1
Do you think it’s an option if I put this self-adhesive foil on the aluminum plate and glue the MT2 print bed (which is 0.95 mm) onto the foil with double-sided duct tape
Would the inductive sensor detect the foil and auto leveling would work? Probably a difficult question but maybe somebody (@Edwin ?) could comment on this.
Sorry for the links to German Amazon link. Couldn’t find the foil on Amazon.com
Thank you so much for your reply and that is very helpful. I can confirm that the proximity sensor will work even if you put tape on print sheet.
I have a plate of 6mm cast aluminum on my A350 as a bed. The sensor detects it just fine as long as you have moved it to the correct 1mm above the nozzle.
Honestly I don’t understand this thing about the sensor calibration. On the one hand the sensor seems to be working out of the box as most people (me included) ca use auto leveling with the default setting. Otherwise, there is a thread in the FAQ mentioning you have to calibrate the sensor before you can use it?!
I had a close look on the extruder when it’s coming down to the platform and I can’t see any red light?!
@DroneOn. Did you run the calibration with the printer powered off like Kerrida described in this article?
The problem with the sensor being set too high is that it only has a 2mm working range. Most if not all of the early units had their sensors set at or above the 2mm limit. SM may have finally fixed this in production but to do it correctly the 3DP module housing would need to have the slotted mounting hole for the sensor enlarged because at 1mm offset the screw is buried into the bottom of the slot. To make matters worse it is attached to the fan shroud inside and when pushed all the way down, it creates a gap for the forced air to leak out and not go where it is intended to go.
You have to set the sensor offset with the unit powered off or risk damage to the bed and head. You are only setting the distance between the nozzle and the sensor to 1mm (credit card thickness) so the red light is irrelevant for this operation. After the offset is done, you reassemble the 3DP head as it should be mounted and then power on the machine to run your auto or manual mesh calibration.
Clear as mud right? Lol
Is there anything else I have to do after reassembling? I calibrated the sensor offset to the 1 mm. Afterwards I did an auto calibration and then ran the pattern test. Problem is (with same filament as before) Every second pattern would not even stick to the bed. Tried all temperature ranges for bed and nozzle, tried offsetting Z -0.05…
Even changing the filament is not helping.
Have you calibrated your extruder steps and flow rate? Also have you cleaned the print sheet with isopropyl?
Done that before. I’m Cleaning the printbed regularly.
Replying to @rchan15 way back in April, because I didn’t see a response (apologies if I missed it in the long thread).
Whenever I see issues with pressing down at point 5, it sounds to me like the sensor goes off the back of the print bed - so it keeps going down because it’s no longer detecting the bed.
Was that it for you, do you think?
Finally I went back to the Snapmaker filament which, at least fairly worked. Looking at the pattern test after doing another 5x5 auto calibration showed pretty bad result. A lot worse than my last try two days ago. Some squares went off the bed pretty easy, some really stuck to the printbed just like my initial printings where I set printhead to close to the bed.
Only things I changed (beside of filament) was re-adjusting the sensor and having two bad head crashes (other thread). May I have damaged the printbed? I mean the nozzle pushed down the bed real hard with ugly noises…
Here’s my M503. Does the G29 values look suspicious??
I don’t know how to go further. Should I adjust the sensor again? Could it be that I set it to high, or even crooked?
If you are going to go to the trouble of machining a new frame, don’t use Alumunuim. Use something with a lower thermal expansion coefficient. Even cast iron or mild steel is better than Aluminium (11.7 vs 23.6 ppm/K), and way cheaper as well. I have been thinking about getting some invar plate (1.6 ppm/K) to machine a new frame from.
Yep. People who spend money on boro are wasting their money. There is no risk of thermal shock at these bed temperatures and the speed that the glass heats up.
