Long story short - I’m frustrated with the bed leveling of the J1. The automatic process leaves a distinct depression in the back left corner of the bed. Printing a simple 0.3mm single layer sheet confirms this. I’ve used shims to correct it, but it’s not perfect, I’d much rather try manually leveling it using the wheels and a piece of paper like I have on other printers before this one. I’m fairly certain that I will end up with better results than what I’m getting from the automatic process and shims.
I’m assuming I can use a terminal and send a Z-height of 0, and then use the touchscreen controls to move the head around the bed? Is there a better way to do it?
Thanks!
